After looking at the MC / MCL converter and it's connections, i found and bought one on Ebay... I intend on running a connection from a Beocenter 9500 (would that be Powerlink or Datalink??) to the MC / MCL....
Then Connecting an IR (hockey puck) to the IR connection and connecting Passive speakers to it....
Basically, using the MC / MCL converter as a Passive off the Beocenter 9500....
Question is, 1) will this work? and 2) What connection do i make off the 9500?? The Powerlink 1 or 2 or AUX link??
THanks, K
