In my opinion the program is much more stable. The old config tool crashed quite often. 5.12 is also faster.
It looks like the new config tool or the new firmware doesn`t like 3rd party IR which are not from Bang & Olufsen. I tried to install the Windows Media Center IR command from Beoworld. It always crashes. After I removed it, my Beo6 works perfectly.
