Latest post 12-11-2011 11:29 AM by f5434964. 6 replies.
Page 1 of 1 (7 items)
  • 12-11-2011 4:06 AM
    Beolab 5 calibration
    Just wondering after the Beolab has been disconnected from power (eg after long blackout) and PIN reentered... Does it need to be recalibrated every time?
  • 12-11-2011 4:46 AM In reply to
    Re: Beolab 5 calibration
    NoSmile
  • 12-11-2011 5:38 AM In reply to
    if yes, could I do this on my own? Does it work with the built in microphone (I'm sure 'yes')  but do I need a special cable?
    regards elmar
  • 12-11-2011 5:52 AM In reply to
    NoSmile
  • 12-11-2011 6:09 AM In reply to
    so BL5 talk via Powerlink?
  • 12-11-2011 9:18 AM In reply to
    • tompa
    • Top 500 Contributor
    • Joined on 06-30-2007
    • Sweden
    • Posts 94
    f5434964:
    Yes, they do thru datalink, but not in this case, because calibration do the speaker it self (has nothing to do with equipment connected to BL5) and you push the square on top of speaker for a few seconds in standby and calibrationstarts (for each speaker one at the time)
    /Tompa
  • 12-11-2011 11:29 AM In reply to
    thanks a lot Tompa! So each speaker does it's setup on it's own...ok fine!
    Regards Elmar
