 Vienna:
 Vienna:
 Hiort:
 Hiort:
You have to order separately.
Strange, when a friend of mine got his BC2 two years ago, the WB for the socket unit was included,
the WB or stand for the Master unit must be ordered seperately.
My ex-demonstration BC2 came with the socket box and wall bracket. I had to make a separate purchase of a wall bracket for the BC2 itself (which otherwise sits on legs on a tabletop). Annoyingly, and typical of B&O, the B&O photographs of the wall mounted BC2 don't show any cabling, when in reality it's just about impossible to hide the thick cable and special plug that runs to the head unit. Even the hollow stem of the wall bracket is not designed to hide the cable. My cable now runs beneath a window sill and is carefully swept around the oval wall support base, so it looks OK if not invisible.
Thinking about the socket unit again, I seem to recall that you locked all the connections into covered sockets on the unit, and that when you then dropped the unit onto the wall bracket that had the effect of securing everything: you then need to press some release clips if you want to lift the unit off the bracket to change any of the connections.
Graham
									    I used to be indecisive, now I'm not so sure. [W C Fields]
