BeoNut1:
I’m also thinking that hitting the “AV-DVD” or the “AV-Aux.” button on the Beo 4 will allow the
BL3 speakers to go in to “Speaker 2” mode so that the screen never comes on, and I therefore
never have to use the “Picture Mute” button. Does this sort of set-up sound possible?
That's exactly how it will work.
I dont use Apple TV but have a TViX Media Box connected via HDMI to a (BC3 type) BV7.
When I press "V.MEM" the screen goes on and all 3 front speakers are playing (speaker 3 mode)
when I select "AV" from "LIST" and hit "V.MEM" after, the screen remains "off" and only the
two front speakers are playing (speaker 2 mode) - same as if playing an audio source.
The "AV" command tells the the TV to handle the signals coming from video sources in the same
way as from "true" audio sources (like CD, radio, ...)
PS: add a Masterlink Gateway and you will be able to control the whole setup via you IOS device.
