I am NOT a teccie, nor do I know what the technical names for all the different types of connections !
Am, considering buying a second hand Beomaster 6500 as a radio /amp for my existing CD player and passive speakers. In theory it should be wonderful.
But can anyone tell me where I can find a photo of the rear of the 6500 that clearly shows the connection sockets I would have to use ? - I will then be able to tell if I can simple 'plug and play' or will have to get adaptors for my CD output and speaker cables.
Cheers
2nd Prize winner in the May 2010 draw
42 - The answer to the ultimate question of Life, the Universe, and Everything
