1st March February 2012
Søren Mexico
- Joined on 09-13-2007
- Mexico city
- Posts 1,621
Re: BeoGram 5000: Platter imbalance/warp issue?
did you loosen the transport screws??
And welcome to Beoworld
Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
Søren Hammer
- Joined on 01-07-2008
- Esbjerg/Denmark
- Posts 554
There are three screws under the buttom of the Beogram that lock the floating suspension system, as my brother in name says, you should firstly be sure that they are screwed all the way in the "Play" direction (counterclocwise).
Next, check if the platter is properly "mounted" on the subplatter, it should be nice and level, just like this:
Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
jimsmac
- Joined on 11-28-2011
- Posts 2
Thanks for the tip! What would I need to tighten the screws, however? I've never seen screws like these before.
Søren Mexico
- Mexico city
- Posts 1,621
If your BG 5000 is like mine, the transport screws are located under the platter, do like this
Dismount your cantilever, one hand hold the arm steady, the other hand grip the cantilever with 2 fingers, wiggle and pull carefully until it comes of, put it aside in a secure place, its worth gold if its OK. Now try if you can get a finger or 2 under the platter and lift it of, if not insert a small item under (green arrow) the platter and lift until you can get a grip with your fingers, carefully wiggle a little until it comes of, be careful we dont want any scraches or marks on the aluminum.
under the platter you will now see the flywheel and this one.
There are 3 transport screws, and 3 plastic taps, red circles, turn the plastic taps until the flywheel is free, turn the screws counter clock wise until you can move the washer so the screw head fits through the hole, turn the screws clockwise until they are well under the washer, 2-3 Mm. In the green circle you can see the hights adjustment, 2 of these are can be adjusted without taking of the top deck, but to get at the 3rd one you will have to take of the top plate. after loosening all taps and screws, press down on the flywheel, it must move freely up and down, turn the flywheel, it should move with very little resistance, check if the belt is there and correct attached.
Put back the platter and check the hights, should be like this;
Have fun, come back and tell us if we did help or not, and enjoy your Black Magic (Vinyl) a pick or 2 are welcome
Page 1 of 1 (5 items)
