When I switched to Phono on Beomaster 5000 this evening, there was a loud hum in left channel only, the right channel is dead quiet. Then I switched sockets, again same thing but this time left channel output was thru right speaker and right channel output was thru left speaker, meaning that the left RCA socket has the problem. I disconnected all other component to see if it will go away, it did not. When I touch the RCA cable or the RCA left socket, the hum goes away.
Again the hum is with Phono input only, all other inputs are fine.
Any ideas what could be the problem here?
Cheers
