Latest post 11-12-2011 10:08 AM by Dillen. 1 replies.
Page 1 of 1 (2 items)
  • 11-11-2011 2:35 AM
    • Yosono
    • Not Ranked
    • Joined on 11-10-2011
    • Posts 1
    Beogram 1202 - Repair Question
    Hi Guys!
    I've recently bought myself a Beogram 1202, a Beomaster 1200, and a pair of Beovox s55 speakers :) Got to say i am very happy, and excited to have this set-up.
    I have already started by stripping down, and carefully restoring/cleaning the Beomaster 1200, which is going well... however, my Beogram 1202 has a slight issue...
    The problem is that the previous owner (who incidently had it from new) failed to mention to me that the arm fails to move into position. I took the back off to see what was going on inside, and found that the thin metal rod (the one with the little white wheel shaped bit of platic on the end) had popped out of position, and was floating around, un-atached to the central cog mechanism. This is obviously why it wouldn't move when prompted, and felt like it had no resistance when moving the arm (The arm just felt like it could swing about in either direction)
    I had to take the central cog/cam off very carfully to take a look at whats happening inside there, and have taken pictures so you guys can see what i'm refering too! I'm in need of help here, because i'm not quite sure how this rod fits back into the equation, and thus provides the arm with it's movement once more. It would be handy to know if there are any parts missing, and if indeed there are any broken parts that i need to know of - hopefully, it is just a case of putting it back into the right position, with no further worries :)
    Any help on this would be greatly appreciated!
    Many thanks
    Lee.
    This is the deck with bottom taken off:
    This is with the cog, and silent switch arm taken off - to show the automatic arm lever that has popped out of position:
    This is the central cog/cam - both top & bottom sides of it - is there anything missing from this??:
  • 11-12-2011 10:08 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beogram 1202 - Repair Question
    Welcome to Beoworld !
    The small nylon wheel runs under a friction plate under the subplatter.
    Take off the subplatter and remove the wire spring and metal plate to gain access to what is underneath.
    In other words, the thin steel rod (as marked in the above photo) goes through the
    key-hole shaped opening in the base and the small wheel runs on the other side (above decks
    but under the friction plate).
    I'm not sure if the friction plate sites correctly in your deck but you will probably be able
    to figure it out when you take a look at it.
    Or post more of those nice photos and we will take a look together.
    The sequence gear looks fine.
