My good old Beovision 7-32 is driving me crazy.
When watching TV in the evening without any lamps/light switched on in the living room it permanently keeps changing the illumination of the screen. That means when there is a dark scene at the screen it visibly turns down the illumination, some seconds later there's coming a brighter scene which makes the Vision Clear thingy turns up the illumination. All that does not happen when there's a lamp switched on in that room.
afaik that Visionclear system consists of 7 (?) different parameters that all SHOULD enhance the viewing comfort, but which ones are responsible for that nasty behavior? scrolled around in the service menu (MENU 0 0 GO) but don't want to mess around there...
Do I have to turn the light on in the room in order to get a reasonable picture?
