Firstly, hello everyone!
I was just given a BeoGram 2000 that had been sat in its box in a workshop for about 14 years, in really excellent condition, manuals and the lot, I was given it in good faith and told it was fully working when it was put in the cupboard, however there seems to be an issue with unit and I was wondering if anyone could help.
Firstly the tone arm seems to be sat too far to the right of the unit and is also actually touching the surface (which does not seem right to me!), secondly if you put a record on the deck and hit play, the tone arm moves way off to the right (right off the edge of the deck) and the turntable seems to emit a very quiet grating noise, after a few moments the deck stops spinning.
I was wondering if there was a simple fix for this issue or if anyone had any ideas what it might be, I'm a technician so I've got no problem opening it up to fix, but didn't want to start poking about in there without any ideas!
Many thanks.
