Hi all - I know there are hundreds of non-working Beocenter 9000's out there so if someone could sell me a plastic frame for the bottom glass panel I'd be grateful.
I need the bottom right hand side/end section only. All of the frames are identical for the whole series of this design of Beocenter so one from a 8000/8500 or 9500 will do.
Chris.
