Hope another member can help me out. I took my BeoSound 9000 from the AV setup to play stand alone with only two Beolab1 speakers connected. I set the system in Option 1 and the system works as it should, also when using the Beo4 remote. One thing does not seem to work. I can't put up the volume. Not on the controlpanel of the BeoSound 9000. Not on the Beo4. The display shows ''Volume 00'', but I can't put it up. The Beo4 I use does not have the specific ''BS9000'' configuration setting option that the old Beo4's had, this newer one has only configuration option ''Audio 1'' & ''Audio2''. Which one should I pick and how can I get the thing to play at a louder volume than 00? Thank you very much in advance for your help!!!
