Dear all
Recently transfered from Windows to Apple. To have ML-functionality within my Mac Mini I found a second hand Beoport at eBay.
Main current setup BS4 (audiomaster) in room 1, BV7 (videomaster) with Beomedia 1 in room 2 and in study (room 3) Mac Mini with Beoport. At the Mac Mini Beoconnect is also running. Beomedia is serving as N.Radio and N.Music source (deselected asa source for Beoport).
I ran BM-link to update firmware of Beoport and then suspended its running. For operation of the system I use Linkplayer. Beoport is in option 6.
What's working - I can hear BS4 radio & CD, N.Radio and N.Music via connected Beoport speakers. Both controls, software at Mac Mini and Beo4 (via IR-eye) work fine. With Linkplayer I can even scroll through the music selection in iTunes (set as A.Mem). I set MacSound as A.Aux and this setting is selected during start & wake-up.
What doesn't work:
1. I'm not able to hear sound from the Mac Mini (nor from iTunes, nor from sources like YouTube)
2. "short" press at off button in Linkplayer doesn't switch of source
Please help! Could this be an issue with the cables (breached USB or sound cable), Beoport box or just wrong software configuration (which I find difficult to understand). As former Windows user I noticed that for sound output only headphone socket is available - shoudn't this be Beoport or it's USB-name.
Thanks!
