        1st March February 2012
									        Søren Mexico
								                - Joined on 09-13-2007
								                - Mexico city
								                - Posts 1,621
										    Welcome to Beoworld
With "blown", du mean, not working, or maybe only a bad surround, please explain. And a pic or 2
									    Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
									        Annon
								                - Joined on 08-06-2011
								                - Posts 5
										    Here's the speaker mounted, those are the 4 clips I removed, but something else appears to be holding the speaker on.
Here's where you can see the foam is ripped.
									        Søren Mexico
								                - Mexico city
								                - Posts 1,621
										    You will have to pry it out with a wide bladed screwdriver, go around prying little by little, take care not to damage housing or driver, there is a rubber gasket between the driver and the housing and they can sit hard, but will come lose.
You have what is known as foam rot, and the foam surrounds can be changed for new ones, search the forum for speaker repair, foam surrounds, or here, repair the other speaker as well, if foam isn't bad now, it will be soon.
When open change the caps in the crossovers.
									        Annon
								                - Posts 5
										    Yep, it looks like the gasket was just a little sticky. I got the driver out and I'm gonna see if I can replace the foam.
Thanks for the help!
									        Søren Mexico
								                - Mexico city
								                - Posts 1,621
										    We like to help and keep these vintage pieces alive, where are you situated, there are different providers for spares on different continents
									        Søren Mexico
								                - Mexico city
								                - Posts 1,621
										    Glue for surrounds here, surrounds I buy here they are very cheap, other members may have opinions about cheap surrounds, but I have made 2 pcs. S45 woofers and 2 pcs. RL 140 woofers, all 4 woofer plays and sound OK since 6 months.
Other members may have recommandations, so wait a little before ordering, I have only experience of the above mensioned.
Check carefully the dimensions and form (profile) of your surrounds before ordering, don't forget to order dustcaps if you use the recommended shimming metod, The RL 140 woofers has a very tight fit in the voice coil so I choose to shim all woofers.
It not a complicated job, it just take some care and time, and together with a cap change your speakers will sound as new.
        Page 1 of 1 (9 items)
