Hello All,
FIrst off, great forum, managed to sort out my whacky sliding door issue by clearing out the smoke clogged sensors so cheers for that !
I was wondering if anyone can help with another issue i'm having...
I've just bought an AUX to headphone jack lead off ebay, decent one, or at least it seems to be, when i put my mp3 player through it, it sounds great no problems, however i've tried hooking it up to my tv using the same headphone out on the tv and although it does work its very crackly, this is in the background and at a decent volume its hard to tell but when its low its quite noticable.
Anyone any ides as to what could be causing this ?
Tv is a Toshiba Regza LCD if that helps.
Hope all is well and thanks in advance.
Cheers
Bob
