jrantala:
I wonder, could this be "corrected" by bending the thin long rod underneath that rotates the tonearm ? Bending the end of it it so that it is effectively a bit shorter should move all the reference points (parking position, record drop areas, end groove start) closer to platter center.
WIll this work or would I just cause more problems by attempting it ?
-jari
If your parking position is to "far" away from the disk, if your 45 and 33 comes down too early and you can't adjust it with the exenters, and if you cant find mecanical wear anywhere in the mec. sequence, the answer is YES.
Start with the adjustment for 45 setdown point (exenter) in middle position, bend the rod until you get setdown more or less correct, then fine adjust the setdown point corretly with the excenter ( 85 Mm. from center), then fine adjust 33 to 147 Mm. from center, the rest pos. should then be nearly paralel to the deck.
Beosound 3000, BL 4000, BL 8000, BG 2404,BG 5000, BG CD50, Beocord 5000, BM 901, BM 2400, BM 4000, BV S45, BV 3702. There is nothing we cannot do, but a lot of things we don't want to do!!
