Latest post 04-20-2011 9:56 AM by joeyboygolf. 3 replies.
Page 1 of 1 (4 items)
  • 04-17-2011 7:46 PM
    beolab 4500 and beomaster 5500
    I have two beolab 4500 active loudspeakers. Are they compatible with beomaster 5500 or beocenter 8000? beomaster 5500 has not power link, is it a problem? Thanks for your reply
  • 04-18-2011 3:12 AM In reply to
    • lausvi
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Helsinki - Finland
    • Posts 498
    • Gold Member
    Re: beolab 4500 and beomaster 5500
    Beolab 4500 has also a 4-pin speakerlink connection. You can use that to connect the speakers to the BM5500. The BC8000 is a cut-down model and it has only 2-pin connection for passive speakers. You can use that but the displays in the speakers will not work.
    Bang & Olufsen - The art of controlling sound, picture and light
  • 04-18-2011 9:09 AM In reply to
    Thanks for your reply. So, i would understand, if i use the 4-pin speakerlink connection of beomaster 5500 the displays and power amplifier in the speakers will work?
  • 04-20-2011 9:56 AM In reply to
    gilbert:
    Correct
    Regards Graham
