Hi all
Started to look at the BL 5000's, got one up and running , now have a problem with the male ribbon cable end on the display feed, its fallen apart, however I think it can be salvaged, just need advice on the type of glue to use, or just double sided tape?
salut
tony
									    I always try to operate using/following the KISS principle --  Keep it simple stupid!
