Latest post 03-20-2011 5:09 PM by Shawn. 7 replies.
Page 1 of 1 (8 items)
  • 06-11-2007 4:16 PM
    p45 speaker stands or wall mounts pjbw@hgrove.wanadoo.co.uk
    is there a wall mounting kit for the p45 speaker or a floor stand ? info gratefully received        peter jb wilkinson
  • 06-11-2007 4:25 PM In reply to
    Re: p45 speaker stands or wall mounts pjbw@hgrove.wanadoo.co.uk
    These speakers were made as wall mounted panel speakers and I thought they came (when new) with the wall mounting parts.
    Regards Keith....
  • 06-11-2007 4:27 PM In reply to
    • Xseries
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Hampshire
    • Posts 433
    The P45s never had a floor stand ( recommended buy from B&O would have been S45s).  They have built in fixing points to the rear.  There are 3 possible positions.  Horizontal, vertical below 1 metre (bass ie lower half angled up) and vertical above 1m (treble angled down).  A template that came with the speakers shows which screw holes marry to the various positions.
  • 06-11-2007 4:28 PM In reply to
    • Xseries
    • Hampshire
    • Posts 433
    No wall mounting parts - just wall fixings matched to the template.  I will see if I can find one!
  • 06-11-2007 4:35 PM In reply to
    Just used some screws when I mounted mine!
  • 07-04-2007 3:08 PM In reply to
    thanks to all i will try screws!               peter
  • 07-04-2007 3:14 PM In reply to
    • Puncher
    • Top 10 Contributor
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    Because of the cabinet volume I would assume they relied on the wall to achieve any sort of bass respone. (and they look the part when wall mounted - they would look properly silly on any kind of contrived floor stands).
  • 03-20-2011 5:09 PM In reply to
    • Shawn
    • Not Ranked
    • Joined on 03-20-2011
    • Portland, Or. USA
    • Posts 2
    So...when mounting in a vertical position...hang one with the woofer on the low end and the other the opposite way?
