I suspect that the BT vision remote will only function with older "pre-bl1ooo" B&O tv's?
It seems to use the standard 36/38khz transmission rate,so won't work with the higher 455khz that current B&O product utilises?
You could probably set up a Logitec remote to work both pvr and tv though.
