Wings:
As captioned, my BS2 has suffered a computer chip failure which will cost around 190 pounds sterling to repair. I have decided not to repair it as it only cost me that amount to buy it [and that price included the A-8!]. Did I make the right decision? If so, what do I do with all the accessories, i.e., table top charger, travel charger and A-8 [one used pair and two new in box courtesy of Beoworld]? Should I do as Peter and use it as a paperweight?
sorry to hear that Wings
mine also failed in 2009 and I asked people's opinion ... iPod versus repair ... everyone said iPod but in the end I repaired the BS2
I still love it ... but I now tend to use an iPod Nano simply because it holds some 500 tracks and I can more easily select what I want
But I think the BS2's sound is superior
If mine failed again I would use it was a paper weight rather than repair it
Your A8s (like mine) should work with any player
As I said somewhere else last week, both my BS2 chargers are suffering from too many road trips
So I would be happy to buy one or both of the chargers from you if you like ... or suggest you put them on eBay to get the best price
First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
