As long as you configure your surround sound processor accordingly. It should have an option to set 'speaker distances', which will delay the sound from a speaker which is nearer to you, meaning each speaker's sound arrives at the same time - supposedly!
When you say mount the speaker behind the TV, you don't literally mean firing into the back of the TV? You should always try and have direct line of sight with each of the speakers.
