As a newbie to the BV7-40 MK3 with DVB-HD, do you have control over what channels are in which groups ?
For a reason that seemed logical at the time I reset all channel data - and now i can't get a single channel group that has all channels in it (correctly numbered (eg with ABC 2 on 22 & GEM on 90) - I did before.
For the australian reader - I seem to have channel groups called Australia (all but ABC), Terrestrial (all channels but numbers are screwed eg SBS on 103), ABC (all ABC).
I've tried reset channels and rescan, as well as reset country and start from fresh - but I can't seem to get back to the point of having a single channel group with all channels with the 'right' channel numbers.
Any thoughts (other than I shouldn't have done it in the first place!) ?
