Hello All, I purchased the replacement battery for beocom2 but have no clue how I can remove the battery cover? Looks like I need a tool once I remove the screws from the magnetic plate and see the other cover holding battery. So frustrating
remove the screws with a torx screwdriver, unplug the cable from the connector, buy a knipex plier for internal rings like this, remove the black plastic part using the plier, shake the phone a bit, voila: the battery comes out.
Marcel
