Here is a posting I put on the Yahoo Beolist sometime back and the solution. Please read the postings from the bottom one up!
Hope it works for you.
Re: Broken Beolink 1000
WOW success!! - it worked brilliantly. Thank you so much, that was
great. To think, I had forgotten about Beolist and haven't been on
here for months.
Thank you
Stoobie
--- In
beolist@yahoogroups.com, "Frank" <frank.ttt@p...> wrote:
> Try this:
> Get out the batteries and short-circuit the + and – contact of
the
> battery holder in the BL1000. Put the batteries back in and try
> again. Some Duracell batteries have very small positive contact
> tips. They give bad contact and cause the microprocessor to crash.
> Success
> --- In beolist@yahoogroups.com, "stoobie_too" <sbs@g...> wrote:
> > Last week my Beolink 1000 was working perfectly. It stopped
> working
> > one night and I assumed the batteries were running low. I
replaced
> > them with new Duracell but it still does not work. I am the only
> one
> > at home so it has not been dropped or damaged. I was using it to
> > teach my new Pronto Remote all the B&O codes.
> > Have I pressed a button combination that has stopped it working?
> > I spoke to my local dealer who says they do not repair Beolink
> 1000
> > but only do a trade for a refurbished one. At £95 it is quite a
> > lot. (I have just had my Beolink 5000 repaired at a cost of
£150
> > so I do not need the extra expense, but find remotes in all the
> > rooms helpful)
> > Any "Techies" out there who can suggest a solution?
> > Thanx
