It could be on the way of going out, but don't worry about that in
advance. CD-Rs are more difficult to read, and many CD players - even if
they are in complete working order - are temperamental with them.
You
might try different brand blanks, and often it helps to burn the CDs at
less than their maximum rated speed. Apparently the end result is
optically better quality then.
