Could someone suggest where I should look to solve an annoying problem? I can not get the volume to reduce. After switching on the volume is about half position and it can not be reduced. On occasions in the past it has reduced with the remote but not with the manual control. Now the remote cannot reduce it either
The volume can be increased but not reduced the only way to reduce it again is to turn the set off and restart. Then it starts at the relatively high level . The other functions all work as expected both with the remote and the touch pads on the set.
This is very frustrating because the sound level is just a bit too high for background music.
Help !!!
John
