Hi all,
I just scored a sweet vintage B&O system! Took a gamble on craigslist and purchased everything "as is" since the seller could not find connection cables to test it out with.
Today I brought home:
Beomaster 1900 Amp/Receiver
Beogram 2402 Turntable (Cartridge model # MMC20 E)
Beovox S45 Speakers
I've already torn the turntable into pieces fixing the arm (would automatically move side to side, but refused to lift... just scraped across my records - all is good now). My next move was to hot wire the speakers into the receiver. Since I didn't have the correct B&O cables, I ran alligator clips into the back.
This system sounds GREAT! Been listening to vinyl all day and love it.
Couple ongoing questions though:
Can I use the Beomaster 1900 as a preamp? I want to hook everything up to my giant Cerwin Vegas to thump at houseparties (honestly, I'm not even planning to use the Beovox S45-2s that came with the system). But the Beomaster (30 watt) doesn't have enough power to drive the Cerwin Vegas (350 watt) at earthshattering levels and my dedicated amp doesn't have a phono input.
Also, one channel on the Beomaster is noticeably quieter than the other. What do I need to take apart/resolder/clean to get these back in balance?
Thanks! Looking forward to being part of the community here.
