All,
According to a page somewhere on this site, the Beolink Wireless 1 supports the Beolink Active.  My interpretation of this "support" means that one can connect the Active to a Wireless receiver and have it work basically as a ML extender.  That is, the Active should behave just like a hardwired Active, correct?
Anyway, I tried this today as I'm thinking of extending the Beo in my home to virgin territory, and it didn't work completely.  If I select a source, the speakers unmute for a second, crackle a short bit and turn off.  Also, the audio master does not turn on.  However, if I select "PC", the local Active PC-input source plays fine - I think the audio master also turned on, but I don't know for sure...
My Active says "SW 1.1" on the back.  Any opinions on whether a software upgrade on the Active would fix this (my Wireless 1 was upgraded about a year ago)?
Thanks,
Stan
