Latest post 12-05-2010 8:22 AM by Spiros. 8 replies.
Page 1 of 1 (9 items)
  • 12-04-2010 5:04 AM
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    Difference between Center and L/R front for Beolab 4000
    Now I'm a bit puzzled and before I start experiments (usually ending on the service center or many hours of rewiring!!) I'd like some opinions. I have on my Beosystem 2 (with the 4-42) a pair of Beolab 4000 on the left and right (front) along with my newly purchased Beolab 11. Do you think that placing the Beolab 4000 (both as a center speaker) would change the sound? Mind that I do not have rear speakers connected because I prefer Stereo and don't so much like the 5.1 Any ideas and thoughts are highly appreciated.
    Best regards
    Spiros
  • 12-04-2010 1:36 PM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Re: Difference between Center and L/R front for Beolab 4000
    Anyone?!?!!?!?!?!
    Best regards
    Spiros
  • 12-04-2010 11:59 PM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Ok. Last try. Anyone?
    Best regards
    Spiros
  • 12-05-2010 1:21 AM In reply to
    The Powerlink cable carries both the left and right channel...
    When you select L, the speaker plays the left channel,
    When you select R, the speaker plays the right channel,
    When you select Center, I am guessing it mixes both channels into one.
  • 12-05-2010 1:31 AM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Hello Phil,
    This is indeed what I have in mind but my main puzzle is whether there would be any issues on the setup in combination with the bl11!
    From my point of view most probably nothing would change but, it's better to ask!!!
    Best regards
    Spiros
  • 12-05-2010 6:34 AM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Of course moving the speakers would change the sound. For good stereo imaging, you ideally want to be placed at an equal distance from the speakers, with the distance between the two speakers being the same as the distance from you to one of the speakers (an equilateral triangle).
    Placing the two speakers right next to each other would just completely defeat the point of stereo.
     Weekly top artists:
  • 12-05-2010 7:29 AM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Hi Alex, This is exactly how they are positioned at the moment. However, this is what I ask. Assuming I change nothing on their position, however, I cable them to center, what would be the difference? But in any case, I have I will try to find a single BL6000 to make it as a center. This is exactly the moment that I regret selling my BL7-1 I used to have.
    Best regards
    Spiros
  • 12-05-2010 8:02 AM In reply to
    I don't quite understand what you want to do.
    L/R Front carries a specific signal which contains sound effects and some voices. But the voice-information in multichannel is carried by the center-channel. If you cable to the center-signal, you will hear voices, but very little (if any - depending upon the mix of the particular movie) of the front sound effects.
  • 12-05-2010 8:22 AM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    It was mainly a test for better sound. I just did it and you are correct. Sound was far away from what I had in mind.
    Bottom line is that I keep everything as is and will place a center speaker as well.
    Best regards
    Spiros
