Latest post 01-31-2011 3:34 PM by joeyboygolf. 2 replies.
Page 1 of 1 (3 items)
  • 01-31-2011 1:59 PM
    Display on Beolab 3000 in connection with Beosound 9000
    Hi All,
    I have Beoloab 3000 connected to BS9000 and was wondering how to get the display working. I have checked the forum and also both user manuals but still no display ....
    I have 8pin powerlinkcables and the speakers are set to 'audio'
    Am I correct to understand that all should work, or should I chang some set-up to my BS9000?'
    If yes, how
    Maybe the displays are broken )on both?) how to test this?
    Thanks .. and good luck with tonights pricedraw!
    BS9000, Beolab 3000, Beocenter 7002, RL60.2, beo4, BV10
  • 01-31-2011 3:24 PM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    Re: Display on Beolab 3000 in connection with Beosound 9000
    sEEMS AS THOUGH YOU ARE USING A mK 3 PL CABLE WHICH IS NOT FULLY WIRED (sorry about caps) a mk fully wired pl should get the display working!
    tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 01-31-2011 3:34 PM In reply to
    All powerlinks are 8 pin but not all pins are connected in all versions of the cables!! Mark I or Mark III cables are no good for your job.
    You must use Mark II powerlink cable or the new fully wired cables which have recently superceded them.
    Regards Graham
