Hi guys,
I have problem with my Terminal 5000, that came with my MCP 5000 from ebay. When I inserted the battery (a 9V one) in it for the first time, it worked fine, but when i checked it after trying the MCP (about 15 mins later), it was dead. I measured that the battery`s voltage was 8,5V when inserted, otherwise it is 9,5 , which means that something is loading it. Than I saw that several seconds after conecting the baterry the remote is working fine, then it suddenly dies, which makes me think that the IC (ETL9411) and the oscilator are fine.
So any ideas?
Thanks in advance, Tonislav
