Latest post 11-05-2010 12:16 PM by Keith Saunders. 8 replies.
Page 1 of 1 (9 items)
  • 10-28-2010 5:19 AM
    software
    can anyone tell me the latest software for the beovision 10 40inch
    many thanks
    malcolm
  • 10-28-2010 6:53 AM In reply to
    Re: software
    The most recent update was made available by B&O earlier this month which they have called "Build 153"
    This manufacturing build 153 for the Beovision 10-40 contains:-
    • PW version 4.05b
    • FEP version 4.03f
    • System Module version 20.06f
    • DVB-HD T/C version 0.1.4.7.0
    • DVB-HD T/C/S2 version 0.1.4.5.0
    • DSM-FEP version 5.18a
    • DSM-DSP version 5.15a
    NOTES on above items
    • PW means PW 328 Application Processor Software
    • FEP means Front End Processor
    • System Module contains Masterlink etc..
    • DSM-FEP means Digital Surround Sound Modules Front-End Processor
    • DSM-DSP means Digital Surround Sound Modules Digital Sound Processor
    Regards Keith....
  • 10-28-2010 8:11 AM In reply to
    Re: software
    Keith,
    A slightly different question, but perhaps you can help.
    I live in the UK and installed a BeoVision 7-40 with a DVB-HD module last June, before the high definition broadcasts started. Once they did start I find that the DVB-HD module in my television cannot pick up high definition broadcasts. I am told the format changed and as a consequence I need a new module. This module was supposed to be available earlier this year. I have now been told it may be next year.
    I assume that the DVB-HD module you reference above can pick up UK high definition broadcasts - otherwise I can't image anyone buying it. Is this a different module to the one I would require for my BeoVision 7-40?
    Thanks for your help.
    Stephen
  • 10-28-2010 9:24 AM In reply to
    Re: software
    many thanks Keith for the info, i need to have my beo5 updated so thought i would
    have  beovision 10 done at the  same time
    as a matter of interest what did the update correct or add to the tv
    malcolm
  • 10-28-2010 11:06 AM In reply to
    Re: software
    Stephen,
    You are correct, your DVB-HD module will not work in the UK and never will.
    You will need to get it replaced with a DVB-HD T2 when available.
    The background to this situation you find yourself in is:-
    The most used standard for DVB (Digital Terrestrial Television) in Europe, including the UK, is DVB-T and some countries have decided to introduce High Definition signals using the same system.
    However, the UK government decided sometime ago to approve a new system to broadcast High Definition signals called DVB-T2. This system uses less bandwidth and significantly higher error correction methods rather than reduce the number of TV channels available
    The UK is/was the first country to use DVB-T2.
    Whilst this UK decision has been known for at least 2 years, perhaps longer, B&O were slow to understand the potential issues for their customers like you and continued to sell DVB-HD modules factory fitted to the Beovision.
    Regards Keith....
  • 10-28-2010 11:13 AM In reply to
    Re: software
    malcolm welborn:
    Malcolm,
    I understand the following issues have been resolved:-
    • Low picture/menu quality on DVB-HD
    • A loud ticking noise is heard when stepping up/down on Humax 5050/5000 set-top box
    • The previous factory Build 126 had issues resolved by this update
    • After a period of time there is no set-top box IR-control
    • Incorrect translation from DVB-HD
    Regards Keith....
  • 10-28-2010 12:54 PM In reply to
    Re: software
    Keith thank you for your quick reply with info
    malcolm
  • 11-05-2010 11:39 AM In reply to
    Re: software
    Keith,
    Thanks for the reply, sorry my follow up is slow but I have been travelling. I don't suppose you have any idea when the DVB-HD T2 will be available?
    regards
    Stephen
  • 11-05-2010 12:16 PM In reply to
    Re: software
    sjmcguckin:
    Well, that's a question many have been asking.
    The problem as I see it is that when B&O sets its priorities its thinking number of sales, but whilst B&O UK will be pushing hard I am sure to make it available here, the management in Denmark may not see the priority at a similar level.
    One thing I think you can be certain about and that it will not be released before 2011
    Regards Keith....
