I have a Jvc DLA-HD 1,A great projector! Have a look at the new models that they have,all have great reviews.
I used mine on a Bv7-40 mk 3 now have 7-55.
You can now get some projectors that do 3D if your after that! Projection is a good way for 3D,as nice big screen sizes,so would get the effect unlike from a tv.
Look around,as you can get projector/screen deals.
Hope this helps.
Bv7-55 & Bv7-32...Blue,lab1's x4,Yes4Blue, 6000x4Blue,Beocom6000 Blue,Beo5.Oh what a Blue set-up & a Beosound 5...After all,its Bang&Olufsen!
