Hi all,
I'm a proud owner of Beovision 10-40 since last december and I really love my tv. However there have been some minor glitches that occur once in a while and I wanted to check if anybody else have been having those problems.
1. TV freezes when watching movies via PS3 connected with a HDMI cable. This has happened twice in the last month or so. Tonight it occured like this: half of the screen froze and the other half of the screen continued to play the movie. Tried to pause, play the movie and then the screen went gray and I couldn't even restart with my Beo5, I had to get the old Beo4. After a restart of the TV everything was fine
2. On several occasions last winter the DTV module restarted itself again and again without no apparent reason. When I changed to an other source ( HDMI ) I could here a clicking sound when the DVT module was going through the reboot loop. Later I came to the conclusion that this happened when the DVB-T antenna had some snow on it ( I have not tested this theory, will do next winter )
3. On one of the + stations ( 1 hour behind ) the audio is so off sync that it is not watchable ( is that a word? ), but I'm not sure if that is a receiver problem or a broadcasting problem.
The dealer has confirmed that the DVT rebooting happened in their showroom aswell as with an other customer. I'm not sure if they have reported those problems to B&O in Denmark, at least they have no answers for me.
Has anybody else been experiencing similar issues with the BV 10-40? Do you have any comments on how I should get the dealer/manufacturers attention to those problems?
Regards
Konrad Hall
Iceland
