Hello all.
Some years ago I aquired a Beocord 5500 which had trouble with the playback head, one channel was dead. Thrue Beoworld I was able to get the mechanics of another BC5500 from where I get the replacement head. The mechs. weren't of the exact same type but I was able to replace the head and get the adjustments so that it sounds good on both directions.
Unfortunately I didn't take note how the three wires to the sensor on the left-hand side of the playback head connect. If I am not mistaken, this sensor senses the signal during winding and enables the use of Return/Advance, ie. moving automatically to the prev/next track. In the current way I have connected it the sensing doesn't work, ie. pressing Advance the tape keeps winding forward without stopping (tested with a tape recorded with BC9000 where the tracks are "marked" and work).
Could someone post here a photo of the correct connection? Or if the signal-senes doesn't work this way what could be causing the problem?
Bang & Olufsen - The art of controlling sound, picture and light
