Hello all. Haven't posted for awhile and I'm back!
We all know that a Beolab 2 will not work in a non B&O application because it has no in-line feature. In order to turn on a Beolab 2 from a non B&O source, there is an adaptor made by B&O which uses a transformer to feeds 6 volts into it to power it on. I hate the transformer because it introduces a faint but annoying buzz into the speaker setup.
I would like to if it is possible to hook up the BL2 to a Krell HTS processor. The processor has a 12 volt DC out trigger. My question is if I feed 12 volts instead of 6 into the BL2, will it blow out? Please don't laugh.
Thanks from Kevin
BeoSound 9000, Beolab 8000, BeoLab 4000. Beogram 4002/Grado Gold Amina conversion.
