Hello,
I wonder if someone in the know might be able to point me in the right direction. I just replaced the RCA leads & ground cable for my Beogram RX turnable, soldering new ones to the internal board, a fairly simple process. Strangely, after hooking it back up when I turn up the volume on my system past a certain point the motor in the Beogram starts to vibrate like crazy to the point where the needle won't track. The more I turn the volume up the worse it gets.
Anyone have a clue what I might have done wrong, or what to look for?
I used a pair of coax Acoustic Research cables, using a comon ground like the old ones and did nothing to the A/C line.
