Often missing and very hard to find unless from a donor Beomaster.
The slider is actually 10 separate parts:
Two Nylon pins at the rear
Rear bracket
Window
Front bracket
Two springy nylon sliders
Three fingerwheels
Sometimes the nylon pins and springs can be found in their respective
grooves in the aluminum dial plate.
