Hi all,
Maybe somebody can help me out with this: My beo4 responds very poor to the keys suddenly
The display is fine and I can switch to V-tape and A-tape and some more (althought the TV does not react). But then I cannot switch to TV back anymore; the display does not react and neither the TV.
Or, to put it in another way: the TV does not react to any key at all, but the remote's display reacts to some keys. I stripped the thing to PCB board level and removed the keypad, cleaned it and so on, but to no avail. It is clear that when I press the buttons directly with my fingernails, the reaction is the same; so either the keypad (i mean the soft see-through thing underneath the rubber keys) is broken or the connection to the microprocessor is malfunctioning.
Is anybody familiar with this?
Kind regards,
Bart
P.s it is not a battery issue.
