Hello.  I am in Japan and visited the showroom today. In my new house, I had been hoping to mount the BeoSound 8 on the wall, but the salesperson said with my Ipad, it is not recommended.  I also worry that, even if noto n the wall, when the Ipad is docked, my cats could knock up against it (an earthquake might cause this too) and bend the docking connector.  Is this a worry?
I am wondering about two possibilities:
1) Just use the line out on the IPad. Or, better yet, just use the line out on my old 2006 MacBook Pro (with a DV cable to the TV) and I could use that as the source instead of the IPad.  I assume this works.   But would the remote still control my volume, or would I have to set it on both the BeoSound 8 AND the Ipad/ Mac?
2) If I DO use the IPAD, is there such a thing as an extender cable, so that I plug one end into the IPad and the other end, terminating in the same type of connector, plugs into the doc?
Thanks in advance!
Paul Arenson
PS
Previewed the tiny AIRPLAY Beo 12 today.  Not bad, but less stereo separation. In some ways comparable to Geneva Labs(M). I much prefer the BeoSound 8 (the cheapest B&O in my budget), which bears some resemblance in sound to the Geneva (L) model, the one that has a CP Player attached.  But still teh B&O 8 sounds better.
