bentleybaz:
any offers / info would be great or just to say " cant have two main sources on same link."
true - but you can set your Ouverture to "A.Opt" "6" to be a secondary system ...
(If it's a very old one you'll need a SW update)
Press "LIST" and "OFF" (red dot) simultaneously
Beo4 display changes to "ADD?"
Press "LIST" till display shows "OPTION?"
Press "GO"
Press "LIST" till display shows "A.OPT"
While pressing "6" watch the standby-led of your Ouverture
a "twinkle" confirms the new option - no "twinkle" means you need an update ...
You'll probably have to add "LINK" to the commands of your Beo4
To play a CD from your BSD 9000 press "LINK" "CD" "1/..../6"
