Hi everyone,
I know the answer is most probably "no", but I couldn't help ask the question. The BS3 has not aux input, but has SD card slot. Does any company make an audio-jack-to-SD-card adapter? The idea is simple: the adapter takes whatever input is coming through, converts it on-the-fly to a psuedo audio file that the end device then reads. The audio file is continuously added to with new information. Basically, an SD card version of the venerable car cassette adapter.
If yes, I will acquire a BS3 at once! If no, well... its usefulness would be much diminished.
Leo
BV 10-40, BV 8-32, BL 9, BL 4, CX100, BS Ouverture, BS 2000, BG 4500, Passive, LC 1, A 9
