Many thanks to Stefan for sending me a TSOP7000 IR receiver, arrived today, soldered it to a 3.5mm jack and now i can switch on my BS2.
Another problem now.... the BS2 switches itself off after about 4 minutes of scart or UHF output.  Have read something about pin code protection but understood no display would output?  Can't get a menu to come up on RF or scart,  have tried entering the service menu but still no display.
Can anyone please confirm if the menu options from the BS2 can only be veiwed on a Beovision 4 (or a monitor using the RGB for the Beovision 4)  Alternatively, is the BS2 switching off because it isn't getting a handshake through RS232 from a Beovision 4 display?
Either way, i think i am going to need to make a cable / buy an interface to convert RGB to VGA or HDMI - if the RS232 socket needs a loop back to trick the BS2 into thinking it has a Beovision 4 connected, is there a tried & tested schematic out there please?
I've looked at the service manual and can't find which connection is used to operate a display, i've tried all the scarts but no luck yet, and one more thing, if i command DVD, Radio etc from the beo4 terminal the BS2 doesn't turn off the TV output on either the RF or the scart outputs.  e.g. if i did the same on the Avant the TV output would terminate even if another source was selected that wasn't connected.
Thanks,  Martin
