A few days ago I've got myself a Tvix 6600 installed. It's connected by HDMI only, to my BV7 mk3.
I have to turn up the audio volume to very loud (>70) to hear the same as a TV-signal (volume of 50).
Can this be changed; settings Tvix or BV7 ?
Hi
I have turned up the volume on the TVIX to MAX (using the Tvix remote), and then it works just fine for me.
There is something about B&O.....
Hi Beolin,
Do you have the tvix 6600 as well?
Don't you control it via the puc-list / beo-remote?
Yes I do, and I control the Tvix via PUC, but you can increase the volume on the Tvix (no PUC code for that). I did that, as I before had to turn up the BV7 volume to 50-60, and now I have the volume at 30-40 on the BV7.
Beolin,
Do you use a beo4 or beo5? With my beo4 I can't seem to skip a movie to another chapter, or go to a "DVD's" menu to change subtitle or other settings....
