Hi All,
Due to getting a BV7 as opposed to a BV5 the DVD2 that I bought is redundant.
It's still under B&O Warranty and was bought from B&O Bath, I'll dig out the recipt to check the dates etc.
I've only ever used the DVD player and never used the recording disk (250GB) and it still has the 'Welcome to B&O' recording on there. :-)
In mint condition and has all the usual connections DVI / RYW / Scart / HDMI / Digital sound out / etc / etc
Has an inbuilt tuner with EPG so you can use it in a similar fashion to a Sky+ /HDR box.
It can also be changed to a multi region DVD player and the instructions are on this site.
I was thinking of £250 (excluding P&P) for a quick sale to go towards a white 5500 stack system I have my eye on!
Cheers
GUY
Train Hard - Run Fast - Hit to Kill!!!
