Hello,
my BV 7-40 + Technisat HD S2 sat receiver works perfectly fine in the TV-room. I use my BEO 4 with PUC and all functions are fine.
Now, operation in the link room is not 100%. I can not make the Technisat HD S2 to switch between TV and Radio radio mode. Switching channel is working as expected, so PUC controll must be fine.
What is not working is to swicht the Technisat HD S2 fome SAT-TV-mode to SAT-RADIO-mode.
To switch in the TV-room I just have to press "MENU" + "5", and it switches. Doing the same in the link room has no effect.
Any ideas?
Regards
Mafanni
