Peter, Et al,
Thanks for the advice.
In searching the site I found this. It makes sense as the CD Head Unit was replaced 18 month ago, and I hear sounds prior to the disk spinning, if it spins.
“The first thing the 9000 tries to do is focus the laser.  If it can't get focus it won't start.
Try cleaning the lens with a Q-tip and denatured alcohol.  If that dosen't do it you probably need a CD mech.
Search the forum for BeoSound 9000 test mode.
TM 65 runs the light pen all the way out so you can get to it”
Thus I went looking and found this sequence for BEO4 commands for entering test mode to clean the optics on my BEO9000.
Here is the sequence I found:
The Beosound 9000 must be in STDBY and if you have no speakers connected you must select Option 1. The remote must be in AUDIO so select CD on the remote.
So the routine is :-
CD, STDBY,SOUND,1,STORE,SHIFT 90258 should get the display reading TEST MODE ON
The problem is, these instructions are vague at best. So..
The first button is CD and it is found on the remote.
The BEO4 manual states that the red dot is “Standby”
“Sound” cannot be found anywhere and is not on the list to be added?????
“1” I presume is the number one on the keypad,
“Store” Does not show up on the List or the add list. (Select does but I am unsure.)
“Shift” was found and added to the list.
Presuming I can find or add these to the remote and I can get Test mode on, How do I clean the optics?
I know how to use Qtips and denatured alcohol, but how do I get the circular shield out of the way, and invoke TM 65? Does it flip out of the way? And finally how do I exit TM? Any help would be appreciated.
Douglas
