Hello all,
Wondered if anyone can help.
I have a beogram 6500 which I bought second hand. It is in excellent condition but when I tried to use it it just shut down. Further investigation revealed that the 'wire' that pulls the arm assy along had come off and was floating around the interior!
Looking into this further, it seems that the cable should attach to the arm assy by hooking onto a little plastic tag which has of course broken off! Has anyone seen this before, Any suggestions for attempting to repair it? I was lucky in that the unit came with an MMC2 in excellent condition :)
One last thing is that when connected to the beosystem 6500 the deck doesn't seem to respond to remote commands - I have checked the DIN plug and the extra pins are present. Are there any 'usual' things I can check here.
Thanks in advance for any suggestions!
cheers,
Adam
